Anpassung: MyDownloads 3.0.2 - Error uploading without image
Fehler beim Upload ohne Vorschaubild in MyDownloads 3.0.2
Fehler
NOTICE: PHP message: PHP Fatal error:  Uncaught mysqli_sql_exception: Field 'preview' doesn't have a default value in
suche in /inc/plugins/mydownloads.php
// add a download to the category's stats $db->update_query('mydownloads_categories', array('downloads' => $cat['downloads']+1), 'cid='.$cat['cid']); $id = $db->insert_query("mydownloads_downloads", $insert_array); }
ersetze mit
// add a download to the category's stats $db->update_query('mydownloads_categories', array('downloads' => $cat['downloads']+1), 'cid='.$cat['cid']); if (!isset($insert_array['preview'])) { $insert_array['preview'] = ''; } $id = $db->insert_query("mydownloads_downloads", $insert_array); }
